doors
Old Feb 22, 2009 | 08:40 PM
rodnok's Avatar
rodnok
Default doors
I have 96 ram 1500 extended cab, no back doors. Will the doors from a 2 door single cab fit?
Also I have been told that the door hinges from a 97 will work on a 96. Is this true? If so I would like to change hinges as the 96's do not have replaceable pins
Old Feb 23, 2009 | 12:37 AM
helms's Avatar
helms
im looking at LMC truck and they have std and ext cab doors using the same part number, so im gonna say that the doors do interchange 94-02.
They also use one part number for the hinges from 94-02, so i guess they are all the same
http://www.lmctruck.com/ICATALOG/DE/full.aspx?Page=47
http://www.lmctruck.com/ICATALOG/DE/full.aspx?Page=51
Old Feb 25, 2009 | 11:10 PM
rodnok's Avatar
rodnok
Default doors
Than you very much. I found 2 southern doors, going to look at them tomorrow. Your info will help immensely
Old Feb 26, 2009 | 12:43 AM
olyelr's Avatar
olyelr
Although I know you were asking about the extended cab and regular cab doors (which are the same door, as helms had stated), I thought I would elaborate and mention that the front doors are NOT the same on a quad cab as they are on an extended cab. The lower corners changed slightly when they made the quad cab doors operational.
Old Feb 26, 2009 | 01:56 AM
helms's Avatar
helms
hmm, i didnt see anything on LMC (not that they are all powerful), but i thought they would have a seperate PN for quad cab doors and ext doors, maybe i just didnt look hard enough.
