Whats the deal?
Old Feb 23, 2009 | 08:53 AM
ROrsburn's Avatar
ROrsburn
Default Whats the deal?
Alright, my truck is a 1995 1500 auto 5.9 4x4. Incase that matters. My problem is that my heat doesnt really warm up unless i have it on the recycle air thing. and then it gets warm so i put it on fresh air and it gets cooler still warm but not hot. Engine temp is normal and all. Could it be the Header core going bad or the termostat, which wouldnt make sense if the water temp is normal. Thanks for your help guys. Ryan
Old Feb 23, 2009 | 09:05 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Heater core is partially blocked most likely. remove the 2 hoses and back flush it. Also make sure your blend door is working properly. You should here it slam open or shut when you rapidly turn the ****.
Old Feb 23, 2009 | 10:21 AM
xskylinedx's Avatar
xskylinedx
It could be the thermostat. If its stuck open your heating will suffer.
Old Feb 23, 2009 | 10:28 AM
zman17's Avatar
zman17
He did say "engine temp is normal and all", so I didn't take him down the thermostat route.
Old Feb 23, 2009 | 10:30 AM
ROrsburn's Avatar
ROrsburn
Thanks guys i will try that when i get it home and washed its covered in a ton of mud
