I found out why my truck has no CEL's
Old Feb 23, 2009 | 04:24 PM
dblj16380's Avatar
dblj16380
Default I found out why my truck has no CEL's
Well, some of you may have read in other posts that I removed my cat and didn't get a CEL. And now, come to think of it, I don't remember when the last time I had one is. Well, I think I found out why. I was curious so I put my key in and turned the ignition to on (so it would flash my dash lights) and here's what I found! Correct me if i'm wrong, but the "Check Engine" light should have flashed too. Right? So now i'm on my way to AutoZone to get the codes read to see if it is throwing anything and the bulb is just burnt out (I still haven't gotten around to getting a scanner). Kinda funny, but kinda not!
Attached Thumbnails I found out why my truck has no CEL's-instrument-cluster.jpg
Old Feb 23, 2009 | 04:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The CEL is suppose to come on momentarily every time you start the truck. Come to think of it, it even goes on momentarily if you just turn the key to the on position.
Old Feb 23, 2009 | 04:42 PM
dodgeram07's Avatar
dodgeram07
wow, best of luck, but i do belive that the light should be on with ignition
Old Feb 23, 2009 | 05:09 PM
dodgeman22's Avatar
dodgeman22
probably just burnt out bulb haha
Old Feb 23, 2009 | 06:33 PM
dblj16380's Avatar
dblj16380
That's what I thought. Everyone in the other posts was amazed that my CEL never came on when I took my cat out. Then I got to thinking about it and I can't remember the last time it came on.
Great, I'll probably go get the codes checked and come back with a 3 page post of stuff i've gotta fix.
Maybe ignorance is bliss and I just won't get it checked! (Just kidding guys)
Old Feb 23, 2009 | 07:06 PM
THEGOLDPRO's Avatar
THEGOLDPRO
i never got a cel when i gutted my cat, and my light works just fine.
Old Feb 23, 2009 | 07:21 PM
dodgewilltravel's Avatar
dodgewilltravel
Default Dash test
On my 2001 1500 318, I test my dash by pushing in on the trip, and holding it in while I turn the key to on, not start, that seems to work well, some people probably didnt know that.
Old Feb 23, 2009 | 10:30 PM
98cherryram's Avatar
98cherryram
that sucks, well best of luck... now you will have to check every so often just to make sure no check engine codes are thrown...
Old Feb 24, 2009 | 06:25 AM
dblj16380's Avatar
dblj16380
Well I am hoping to get to AutoZone soon to get the computer read for any codes (hopefully none) then maybe this weekend I will tear into it and replace the bulb.
Old Feb 24, 2009 | 06:20 PM
dblj16380's Avatar
dblj16380
So I stopped at AutoZone today after work and here's what I found out:
1) Yes, my CEL is burnt out
2) Yes, removing your cat WILL throw a CEL (You just can't see it if the light is burnt out)
3) The governor pressure sensor and solenoid in the 46RE trans ARE prone to failure and mine is no exclusion.
So now I get to:
1) Tear my dash apart to replace a stupid light bulb so I don't have to go to AutoZone all the time to see if there are codes.
2) Test out the non-fowler trick to shut the O2 Sensor code off.
3) Drop my trans pan AGAIN to replace the governor pressure sensor and solenoid. (Hmm, this explains why my trans has been slipping/hesitant shifting into 2nd every once in a while when lightly using the pedal).
Just thought you all would like an update!
