Check engine light
Old Feb 26, 2005 | 01:22 PM
bamory's Avatar
bamory
Default Check engine light
I have a 99 5.9 Ram 4x4 sport on my way home today the check engine light came on truck is running fine but just before it came on i heard a click click click that was simulatanious with the wheel turning could have been a stone or something in my tire cause it moved about the same way...now the engine light isnt connected to anything lower so why would it come on it runs fine, i did clean the o2 sensors the other day wonder if its that..anyone how do i reset the computer just unplug it from battery for a bit like i did my F-150 cause im telling you that im not going to go and pay 200.00 for thenm to clear a random code....any info helpful
Old Mar 31, 2005 | 04:46 PM
kal's Avatar
kal
Default RE: Check engine light
If you go to autozone they can read your code for free and reset it for you.
Old Apr 1, 2005 | 01:33 AM
Leonard's Avatar
Leonard
"i did clean the o2 sensors the other day wonder if its that..anyone how do i reset the computer just unplug it from battery for a bit "
How did you clean your O2 Sensors?
I have heard that it is impossible.
I might have to experiment with some brake cleaner next time I have to swap one out.
That could be the source of you CEL.
Unhooking the negative terminal for a few minutes will clear any trouble codes.
You can always use that time to clean the terminals.
I would pull the codes first though.
Many auto parts places will do that for free.
Old Apr 1, 2005 | 05:15 AM
casper's Avatar
casper
Try this: Check codes
Old Apr 2, 2005 | 05:43 PM
bamory's Avatar
bamory
i just took both sensors out and used carb cleaner and a toothbrush soaked em for a bit and put them back in no problems for 2000 miles now, they do have little holes on them that the fluid can penetrate...
