Wheel weights
Old Feb 27, 2009 | 06:23 PM
Aubrey's Avatar
Aubrey
There's several options to balancing. Pound on lead weights, stick on lead weights, automatic wheel balancers, beads, etc.
Old Feb 27, 2009 | 08:05 PM
dodge15004x45.9's Avatar
dodge15004x45.9
I dont want to see the wheel weights.
Old Feb 27, 2009 | 08:56 PM
96RamSLT's Avatar
96RamSLT
why dont you put the regular wheel weights on but just use black ones that you couldnt see unless you stick your nose against your rim?
Old Feb 27, 2009 | 09:09 PM
dodge15004x45.9
they looks like $hit. and with rims now cant have that!
Old Feb 27, 2009 | 09:28 PM
96RamSLT's Avatar
96RamSLT
worth a shot.. then i guess try the beads or an internal weight
Old Feb 27, 2009 | 09:58 PM
dodge15004x45.9
Hope to get the tire on Tuesday so I will have to let everyone know what I do.
Old Feb 27, 2009 | 10:46 PM
hometheaterman's Avatar
hometheaterman
Have them do a static balance. That's what I do on my truck. Or use stick on weights. Usually I used regular weights on the inside and stick on weights on the inside of the wheel also but near the edge on the inside. The inward edge. I do not like weights on the outside of the wheels at all.
Old Feb 27, 2009 | 10:53 PM
dodge15004x45.9
what dose that mean static balanced? like what will they do?
Old Feb 27, 2009 | 11:51 PM
BlueBeast2's Avatar
BlueBeast2
They put the weights on the inside facing part or the rim. Its fine to do that but I have heard not the "best". I would do though if I ever got rims. I think my stang is set up that way I'm not sure
