Burning oil
Old Apr 15, 2009 | 02:12 AM
J415's Avatar
J415
Originally Posted by dakotas ram
ive got 115k and switched to syn with no problems
You switched at 115k? how many miles have you used synthetic for? It took me about 6 to 8k miles before I saw it leak.
Old Apr 15, 2009 | 02:34 AM
dakotas ram's Avatar
dakotas ram
only about 4 months
Old Apr 16, 2009 | 06:18 PM
Ram2K1's Avatar
Ram2K1
If you don't want to go syn, get the Mobil 1 Clean 5K...a good conv, IMO...and $11 for 5 qts.
Old Apr 16, 2009 | 07:20 PM
PurplDodge's Avatar
PurplDodge
Mobil Clean 5000 is a synthetic blend, right? I use that in my mowers and that stff is great for being so cheap! It is cheaper than AutoZone convential!
Old Apr 18, 2009 | 02:14 AM
J415's Avatar
J415
only about 4 months
My valve covers were the first to start leaking, then my rear main and front seal soon followed. I hope this doesn't happen to you but I honestly think its right around the corner. Seeing as how you just switched. I have since switched from royal purple to straight conventional oil. Keep a close eye on those leaks.
Old Apr 18, 2009 | 04:40 PM
CSXfan's Avatar
CSXfan
Just an update, the plenum gasket was the problem. I replaced it with a Hughes kit, 1000 miles later no leaking or burning oil.
Old Apr 18, 2009 | 06:07 PM
dakotas ram
well, when i switched, i was changin my bent rod, so i got new valve cover gaskets and oil pan gasket, dont think i changed rear seal tho
Old Apr 18, 2009 | 07:04 PM
Cereal Killer's Avatar
Cereal Killer
Glad to hear you got your plenum fixed.
On another note I switched over to amsoil with about a 100,000 miles on the motor and have not have not leaked a drop in the 20,000 miles I've put on it since. It's kind of expensive but it's totally worth it. They started using it in the vans where I use to work (Because you only have to change it every 25,000 miles, although I personally never go past 10,000) and some of those motors had 180,000 miles on them so we figured it'd leak right through the seals. No problems though. Really great stuff
Old Jun 23, 2013 | 09:07 PM
frenchy2991's Avatar
frenchy2991
Default oil
just got my 98 dodge 1500 5.9 back from my sis not running at moment but was told they had to fill it with oil every 100 miles.....plenum gasket?
Old Jun 23, 2013 | 09:16 PM
Arde's Avatar
Arde
I would think that a plenum sucking that much oil would be creating a hallacious smoke screen behind you. Sounds more like a bad oil leak.
