Governor pressure sensor location
Old Mar 5, 2009 | 12:56 PM
kylegrand's Avatar
kylegrand
Default Governor pressure sensor location
I am replacing the governor pressure sensor on a 1996 Ram 1500. I was just wondering exactly where it is? I know it's by the valve body on the transmission.
Old Mar 5, 2009 | 01:11 PM
helms's Avatar
helms
its on the valve body, if you pull the pan and compare to the new one... you cant miss it
Old Mar 5, 2009 | 05:03 PM
bluebomber2500's Avatar
bluebomber2500
im thinking about doing mine, it used to throw a code every now and then, but it has been a while. How hard is it to change out?
Old Mar 5, 2009 | 09:03 PM
ronmexico's Avatar
ronmexico
Its pretty easy I did it a few months ago. Just drop the pan and its right there. While your at it may as well replace your filter too. I think it needed like 3-4 quarts to refill.
