Tail Light Out
Old Mar 7, 2009 | 04:25 PM
05DodgeRamHemi's Avatar
05DodgeRamHemi
Default Tail Light Out
Well now that my third brake light likes to work intermittently; my driver side tail light wanted to join the bandwagon. I can't really risk getting pulled over for a tail light because of the dark tint and loud exhaust, so I had to make an appointment with the measly dealership to see why the tail light isn't working (yes, i replaced the bulb). Must be a faulty wire or something..
Old Mar 7, 2009 | 11:05 PM
J415's Avatar
J415
Blown fuse?
Old Mar 8, 2009 | 02:35 PM
dblj16380's Avatar
dblj16380
I know a couple of years ago my drivers side lights started intermitently working. This was the brake light, backup light and the turn signal. Everything else was working fine and I couldn't for the life of me figure out what the problem was. I ended up jumping under my truck and the plug connector that hooks the wires from the front of the truck to the housing had wiggled itself loose and started loosing connection. I pushed it back together and clipped it in and everything has been good since then.
Just a thought, but you could double check that before you have to spend a **** load at the stealership to figure things out.
EDIT: Wow, I actually typed in $h!t (but the real spelling) and it automatically put **** instead. I just thought that was kinda funny.
