fuses
Old Mar 7, 2009 | 05:55 PM
PURPLE.ppl.EATER's Avatar
PURPLE.ppl.EATER
Exclamation fuses
Quick needed answer for a question, What is the fuse number for the dome lights in a 98 dodge ram 1500????
sorry if its in the wrong forum. please help!!! Thanks for any info.
Old Mar 8, 2009 | 02:42 PM
dblj16380's Avatar
dblj16380
You should be able to pop off your fuse cover and it has a diagram on the back of the cover that says what each spot is and what fuse amperage it takes. If I had to guess I would say 10 or 15 amps. But that is just a pure guess.
Old Mar 8, 2009 | 03:18 PM
zman17's Avatar
zman17
Retired Moderator - RIP
None of them are for the dome light, LOL
Old Mar 8, 2009 | 03:37 PM
TMS Bill's Avatar
TMS Bill
Yeah, I actually went out and pulled each fuse to see which one shut off the dome ... none of them do. Kinda leery about pulling stuff under the hood.
Old Mar 8, 2009 | 05:37 PM
zman17's Avatar
zman17
It's wired into the headlight switch and only uses a relay. The relay related to the headlight switch that is.
Old Mar 8, 2009 | 06:32 PM
01 silver ram 1500's Avatar
01 silver ram 1500
i could be wrong but on my truck i had that fuse go and my dome lights would not go on and my obd2 port had no juice to it... so i took it too my buddies shop and he printed out the wiring diagram and it was the fuse in the fuse box inside the cab with the weird clip on it that looks like it is not supposed to be taken off but you have to... and i believe that it is a 10 amp fuse
Old Mar 8, 2009 | 07:44 PM
aim4squirrels's Avatar
aim4squirrels
If the Ignition Off Draw (IOD) fuse blows the do-me light won't work. It's got one of those stupid protector thingys on it.
Old Mar 8, 2009 | 08:25 PM
APA228's Avatar
APA228
It should be fuse 12 10 amps. If you have power mirrors they should be on the same fuse, so if they are working the dome light bulb could be bad.
