smoke out exhaust and oil is getting low
Old Mar 14, 2009 | 04:10 PM
butchistheman334's Avatar
butchistheman334
Default smoke out exhaust and oil is getting low
Hello everybody i need a little help i just got the truck it has 109,000 miles on it and i get alittle bit of smoke out of the exhaust and my oil is going down pretty quick any ideas on what it could be and how much it would cost on average
Dodge ram 1500 5.2 2WD
Old Mar 14, 2009 | 04:52 PM
Ram2K1's Avatar
Ram2K1
Welcome, Butch. Could be plenum, rings, etc...start by searching to see how to check your plenum. Rule that out first...
Old Mar 14, 2009 | 04:55 PM
dhvaughan's Avatar
dhvaughan
welcome butch. i got $1 on the plenum. lets hope its not the unspeakable.
Old Mar 14, 2009 | 05:13 PM
lastrights's Avatar
lastrights
welcome to the forum there is a search if you ever want to know something fast , lots of write ups and talked about threads
Old Mar 14, 2009 | 05:14 PM
butchistheman334
Whats the best way to check the plenum?
Old Mar 14, 2009 | 05:19 PM
dhvaughan's Avatar
dhvaughan
remove air filter, open up TB and shine a light down in the bottom. you can see a lot better if you completely remove the TB. if you've got a puddle of oil down in the bottom of the belly pan, then its leaking. 101% of all these engines develop a leak... damn dodge. usually the engine is tilted backwards slightly and the puddle is at the rear.
