please help girl with tranny problem
Old Mar 14, 2009 | 08:14 PM
ronintiff's Avatar
ronintiff
Default please help girl with tranny problem
hi,
new here and have a question.I have a 1995 dodge ram 318 engine.
I was driving it for about 20 miles then it started slipping a little ,stopped and put a quart of fluid in. started out fine then after about 10 seconds
it would not move at all .turned the engine off ,waited a minute and turned back on .it moved forward for about 10 seconds then stopped again. same thing in reverse. what could be wrong? update+truck sat for about a hour then tried to move it and it went about a mile then quit again.
please if you have any ideas let me know.
thanks
tiffany
Old Mar 14, 2009 | 09:01 PM
ronintiff's Avatar
ronintiff
bump help any ideas ?????
Old Mar 14, 2009 | 09:16 PM
wjxavier's Avatar
wjxavier
has the tranny ever been rebuilt before or been changed? or is it the original tranny? are the fluids all full? sounds to me like you need a new one.
Old Mar 14, 2009 | 10:14 PM
TMS Bill's Avatar
TMS Bill
The transmission's overfilled ... drain the quart out and start over. Too much fluid foams and foam = mostly air. The system can't run on air. You wait a while ... the foam dies down ... start it up, drive a bit, foam builds up, quits again.
Fill the tranny 1 pt at a time.
Old Mar 14, 2009 | 11:55 PM
wjxavier's Avatar
wjxavier
what he ^^^ said.
Old Mar 15, 2009 | 10:58 AM
ronintiff's Avatar
ronintiff
thanks ,I will try that . hope its something simple (sigh).
Old Mar 15, 2009 | 11:58 AM
TMS Bill's Avatar
TMS Bill
You do know how to check transmission fluid level, yes?
For those who don't:
Make sure the transmission is at operating temperature.
Park the vehicle as levelly as you can.
Set the brake.
Slowly cycle through the gears ... P R N D 2 1 and then back ... 2 D N R P ... pausing for a second or two at each spot. This makes sure all the little nooks and paths are filled.
Put the selector in "N".
NOW check the stick.
Old Mar 16, 2009 | 01:37 PM
dblj16380's Avatar
dblj16380
Set the brake.
That is unless you get the shift kit in it that allows fluid flow and TC charge in park!
Good step by step though!
