DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   37's What size lift do I need? (https://dodgeforum.com/forum/2nd-gen-ram-tech/193587-37s-what-size-lift-do-i-need.html)
theblackhole Mar 16, 2009 07:30 PM
I found a guy that will give me H1 Alpha 37x12 tires for around a $100 a piece. What size lift do I need to fit them on a 2001 1500 5.9L v8
xskylinedx Mar 16, 2009 08:21 PM
more than 5.5 inches and your going to need different wheels.
Silver_Dodge Mar 16, 2009 08:26 PM
1 ton axle upgrade, and probably 6" of suspension lift or better.
theblackhole Mar 16, 2009 09:25 PM
thanks guys, beginning to sound like its not worth it yet
bluebomber2500 Mar 16, 2009 09:59 PM
if you are looking for an inexpensive route, a 2 inch coil spacer with a 2 inch add a leaf plus a 3 inch body lift might leave with only a small rub
dsertdog56 Mar 16, 2009 10:33 PM
I agree with the one ton axles and at the minimum a 5.5 lift. Those are heavy tires!
Silver_Dodge Mar 16, 2009 11:28 PM
I run 3" suspension lift and 3" body lift, and I doubt I could run 37's without rubbing on the lower fender well if I were turning and flexing at the same time. You really need more then 3" of suspension lift in my opinion.
theblackhole Mar 17, 2009 07:59 PM
after looking at some of the other threads i felt 7 inches would be the min and definitely the axle swap. but at that rate I'll look at getting a 2500 and then a lift and tires
© 2026 MH Sub I, LLC dba Internet Brands
