37's What size lift do I need?
Old Mar 16, 2009 | 07:30 PM
theblackhole's Avatar
theblackhole
Default 37's What size lift do I need?
I found a guy that will give me H1 Alpha 37x12 tires for around a $100 a piece. What size lift do I need to fit them on a 2001 1500 5.9L v8
Old Mar 16, 2009 | 08:21 PM
xskylinedx's Avatar
xskylinedx
more than 5.5 inches and your going to need different wheels.
Old Mar 16, 2009 | 08:26 PM
Silver_Dodge's Avatar
Silver_Dodge
1 ton axle upgrade, and probably 6" of suspension lift or better.
Old Mar 16, 2009 | 09:25 PM
theblackhole
thanks guys, beginning to sound like its not worth it yet
Old Mar 16, 2009 | 09:59 PM
bluebomber2500's Avatar
bluebomber2500
if you are looking for an inexpensive route, a 2 inch coil spacer with a 2 inch add a leaf plus a 3 inch body lift might leave with only a small rub
Old Mar 16, 2009 | 10:33 PM
dsertdog56's Avatar
dsertdog56
I agree with the one ton axles and at the minimum a 5.5 lift. Those are heavy tires!
Old Mar 16, 2009 | 11:28 PM
Silver_Dodge
I run 3" suspension lift and 3" body lift, and I doubt I could run 37's without rubbing on the lower fender well if I were turning and flexing at the same time. You really need more then 3" of suspension lift in my opinion.
Old Mar 17, 2009 | 07:59 PM
theblackhole
after looking at some of the other threads i felt 7 inches would be the min and definitely the axle swap. but at that rate I'll look at getting a 2500 and then a lift and tires
