New guy here..2000 Ram 1500...please help!
Old Mar 17, 2009 | 08:06 PM
tru-ram's Avatar
tru-ram
Default New guy here..2000 Ram 1500...please help!
Hi, a friend of mine is giving me a Ram 1500 for free but the rear axle is shot. the drive line is good but the rear axle pinion and carrier is shot and maybe the axle shaft gear teeth. i went to the shop and they quote me $3000.00 dollars to get it fixed. i was wondering if i can get a spare rear end from other dodge vehicle or should i just look for the same year ram or wht? please help. i checked every where and the junk yard don't have the exact one and im just not sure of spending this much. thanks in advance for al the help.
its a v-6 and not 4wd i believe. oh and auto.
Old Mar 17, 2009 | 08:19 PM
wjxavier's Avatar
wjxavier
you can shop around used auto parts stores nationwide and can probably find one much cheaper and they'll ship it to you. i do it all the time for major stuff like that.
Old Mar 17, 2009 | 09:25 PM
TMS Bill's Avatar
TMS Bill
Year would help but not essential. Any corporate 9 1/4" rear end should work. Make sure it has the RWSS mounted to the diff.
Old Mar 17, 2009 | 10:26 PM
mr.318's Avatar
mr.318
A 94-2002 is the same i know just make sure it's got the same gear ratio,3000 is way to high you can get a rebuid kit for under 500
Old Mar 17, 2009 | 10:35 PM
dhvaughan's Avatar
dhvaughan
$3000. that's pretty funny.
just get an entire 1500 rear end housing and differential from the junkyard that matches yours.
1. take a look at the top of your rear diff for the speed sensor. i don't know if all years 94-01 have that thing or not.
2. determine your rear end gear ratio. if yours is 4wd, then you need to get one with the same gear, since front/rear have to match. if yours is 2wd, then you can use 3.55, or 3.73? or 3.92? or 4.10 or whatever you find or prefer. i think there is a 3.2x for manual transmission - DON'T get that unless that's what you have now.
3. new one might be open carrier or LSD. either will work.
that's about the only things to worry about. otherwise they are all 9.25, and all the same size. the brake cylinders are a little bigger on the 00+, but you can keep/swap whatever you want off yours, other than you need to leave the new ring/pinion in the new housing. you can also keep/swap the leaf springs, as they come in 4, 5, and 6 leaf packs. if you can't find one local, hit the internet yards, they can have you one in no time.
Old Mar 20, 2009 | 07:44 PM
tru-ram's Avatar
tru-ram
can i use a rear end out of the dodge 15 passenger van with the same year?
Old Mar 20, 2009 | 07:52 PM
dhvaughan's Avatar
dhvaughan
sorry, i don't know. you would need to check the location of the spring perches, shock mounts, speed sensor, overall width.
