More fun to spend on the engine.
Old Mar 18, 2009 | 10:06 AM
01dabram20's Avatar
01dabram20
Default More fun to spend on the engine.
I was under my truck last night looking and noticed that my plenum gasket is now leaking antifrezze down the front of the block and that my axle seals need replaced. Is there any brand of axle seals i sould use or does it matter?
Old Mar 18, 2009 | 10:10 AM
mcss8541's Avatar
mcss8541
I've never had a problem with the brands available at Autozone or O'Reilly's.
Old Mar 18, 2009 | 04:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If you have never replaced the seals in the front, do a lot of research before you tackle the job. You need a special tool for the right side and you have to remove the carrier to do the left one.
Old Mar 19, 2009 | 12:24 PM
01dabram20's Avatar
01dabram20
I plan on doing alot of research before I change it. Plus i'm going over to a friends to do it since they have done it before on their 97 1500. So he may have the tool for it too.
Old Mar 19, 2009 | 05:33 PM
zman17's Avatar
zman17
You can buy a seal kit with the tool here www.quad4x4.com , and pavementsucks has a write up on how to make your own.
