Changing Speakers (infinity system)
Old Mar 23, 2009 | 11:59 AM
RamWood's Avatar
RamWood
Default Changing Speakers (infinity system)
I am going to change the front speakers. I have a high output deck that puts out enough RMS to power them shown here:
http://www.crutchfield.com/p_107DB52...ures_and_specs
I then will not need the amp that comes with the original system.
1) where do they put the amp so I can take it out?
2) Any issues you can see with this install?
I was just going to run all new wire, and put the new speakers in the same mounting locations that the original speakers were located.
thanks in advance!
Old Mar 23, 2009 | 12:17 PM
BaiN631's Avatar
BaiN631
Those speakers will not be compatible with the door speakers.
Old Mar 23, 2009 | 03:19 PM
jasonw's Avatar
jasonw
Site Moderator
The front door speakers are 6x9, the rears 5.25". You can adapt either to 6.5" pretty easily I guess, so I don't know why you couldn't adapt the fronts to 5.25". My question is... why would you want to? I'd go 6.5", better speakers usually.
If you have the factory "high end" infinity system, or just the infinity speaker system, the amps are two separate boxes, one attached to each front speaker. The rears do not have any amps attached to them.
Old Mar 24, 2009 | 09:34 AM
RamWood's Avatar
RamWood
I didn't know that the fronts were 6x9? I must have put something into the crutchfield site wrong? yes I will deff. look for something in th 6.5" size then.
thanks for the help.
