Thicker Coils in 1500
Old Mar 24, 2009 | 05:51 PM
Aubrey's Avatar
Aubrey
Default Thicker Coils in 1500
For those running 3/4 or 1 ton coils in their 1500, do the coils seat ok in the upper and lower perches? I've heard they do not seat well because the coil is thicker. - thanks
Old Mar 24, 2009 | 06:00 PM
dodge15004x45.9's Avatar
dodge15004x45.9
off topic thing here but what kind of bumper do you have and whats the weight? How much did yr truck go down when you put it on?
Old Mar 24, 2009 | 06:10 PM
pcfixerpro's Avatar
pcfixerpro
Shoot him a pm next time instead of jacking his thread.
As far as the coil spring question, I would have to say that I haven't heard anyone having an issue from those who have done the swap. I doubt you would have a problem but it is always good to double check. I know this guy did it so you might try your luck and shoot him a pm. https://dodgeforum.com/forum/members...odgeguy97.html
Old Mar 24, 2009 | 06:23 PM
Silver_Dodge's Avatar
Silver_Dodge
Aubrey, check with olyelr. I'm pretty sure he's done it and would know for sure.
Old Mar 24, 2009 | 06:25 PM
dodge15004x45.9
[QUOTE=pcfixerpro;1602428]Shoot him a pm next time instead of jacking his thread.
Cook yr jets!! I told him I was jackin it.
Old Mar 24, 2009 | 06:58 PM
Silver_Dodge
That doesn't make it any better. Do a PM next time.
Old Mar 24, 2009 | 07:01 PM
Viper37's Avatar
Viper37
Why do you need larger coils?
Old Mar 24, 2009 | 07:33 PM
PurplDodge's Avatar
PurplDodge
Lift?
Old Mar 25, 2009 | 12:36 AM
olyelr's Avatar
olyelr
Aubry, I replied to your PM. But for anyone else searching, the 3/4 ton and 1 ton coils fit/seat fine in a half ton with no problems. But the 3/4 ton gasser coils will not gain as much lift as the diesel coils.
Viper, the reason he wants the stiffer coils is cause he has a heavy front bumper on his truck which is sagging it down. The diesel coils will support the weight much better and also gain 3" or so of lift.
Old Mar 25, 2009 | 01:50 AM
notanexit7's Avatar
notanexit7
Anyone know where to get these springs or do i just have to check a junk yard. Rather have the bigger springs than spring spacers.
