FRont wheel bearings
Old Mar 4, 2005 | 08:08 PM
lAGA's Avatar
lAGA
Default FRont wheel bearings
I would like to try to replace the bearings myself. I already have the bearings. My question is.... is the bearing-hub assembly pressed on or is there a nut holding them on ? I dont have a lot of free time so any info before I start would save time and effort. Thanks
Old Mar 5, 2005 | 03:27 AM
dodgeballz's Avatar
dodgeballz
Default RE: FRont wheel bearings
Actually its not that bad of a job....The wheel bearing comes as a complete hub usually (its a hell of alot easier that way) I have it down to about 15 minutes each side myself, I am running with a bad set of control arms on one side (time for skyjackers...........) and i usually have to change the wheel bearings every time i change my oil (LOL) Thank god they have a one year "No Questions Asked" warranty, so i keep trading them in for new ones at Advance Auto...Anyhoo...check this out, it aught to give you a good idea on what you're in for before you dive in....-->
http://www.pavementsucks.com/tech/hub.php
Good luck--
Dylan
Old Mar 5, 2005 | 12:31 PM
lAGA's Avatar
lAGA
dodgeballz Wow super responce I couldn1t have expected better info than that I shouldn`t have any problems no. Thanks
