heads coming off
Old Mar 29, 2009 | 01:48 PM
engineblock's Avatar
engineblock
Default heads coming off
i am going to pull my heads pretty soon but i was wondering if i take them off do i have to reface them at a machine shop
Old Mar 29, 2009 | 01:52 PM
dakotas ram's Avatar
dakotas ram
nah, you dont have to.....what are you doing to them?.....when i bent my rod, i wentahead and ported them and got a valve job and the shop checked em and said they were warped just alittle, but should be fine....but for the extra $20 or so i went ahead and had em resurfaced.........i would check them at least
Old Mar 29, 2009 | 01:56 PM
xskylinedx's Avatar
xskylinedx
Take them to the machine shop and have them check for warping. If warped get them
resurfaced, if not warped then don't bother.
Old Mar 29, 2009 | 02:45 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
^^^ +1 xskylinedx
Old Mar 29, 2009 | 08:26 PM
aim4squirrels's Avatar
aim4squirrels
Heads are out of spec if any gap is over .012inches when compared to a perfectly flat surface. Any larger and you should get it machined. If you we're unlucky enough to have a .015 gap on the heads and block there would only be a .010 thickness of gasket keeping the head sealed and that won't have the right amount of compression on the gasket in that spot to seal.
