injector problem on a 5.9L
Old Mar 5, 2005 | 03:09 AM
darin1's Avatar
darin1
Default injector problem on a 5.9L
Can any one please help me? I have a 2001 2500 4x4 5.9L it will not idle. I got a code reader and it gives me the code 205 & 207 ( 5 and 7 injector circuit malfunction) I swapped the 5 and 7 injector with 1 and 3 , the problem did not follow. I checked the wires from the PCM to the injectors they are good. is the PCM the problem?????
Old Mar 7, 2005 | 02:19 PM
steve05ram360's Avatar
steve05ram360
Default RE: injector problem on a 5.9L
I suggest you start with a tuneup, this will eliminate the cap, rotor, plug and wires as a potential problem, also you might look down the throttle body to see if there is any oil in the intake, if there is you have a leaky plenum gasket...and this may be contriubuting to your problem.
