When the defrost is on windshield I here something on or by the motor making a clicking sound and constantly cycling on and off approximetly every 20-30 sec i think somone had mentioned something about the condensor anyone got any ideas of what the problem is it definitly doesnt sound right thanks for any help in advance. cause i know you guys always have the answer
This is normal, I believe. The condenser clicks on and off to remove the moisture in the air, whether you have the temp set to cold or hot. Mine does the same thing.
