Need Help Wheel Base?
Old Apr 2, 2009 | 01:22 PM
Hurley1860's Avatar
Hurley1860
Question Need Help Wheel Base?
I need to get coil springs for my truck and im not sure what size wheel base it is? I mesured myself but not sure if im right. I got 118" or 2997.2mm. Its a 2000 Dodge Ram Reg Cab Short Box 5.2L V8. Do you know. And they also want to know weight load? Thanks in Advance
Old Apr 2, 2009 | 01:40 PM
Hurley1860's Avatar
Hurley1860
Anyone? Please.
Old Apr 2, 2009 | 02:00 PM
helms's Avatar
helms
if the coil manufacturer is asking what wb your truck is, they will know all the different possibilities, i would call them and say your not sure, but you got 118", they will be able to figure it out. you would only be off by a couple of inches, if any.
Old Apr 2, 2009 | 03:08 PM
Hurley1860's Avatar
Hurley1860
Ok thanks, also how hard is it to put coil springs in? An how long does it take?
Old Apr 2, 2009 | 03:28 PM
brosnibean's Avatar
brosnibean
it won't be that hard if you have a coil compressor
btw, motortrend says the wheelbase for a 2000 dodge ram short bed with reg cab is 3015 mm, so that is actually close to your measurement
Old Apr 2, 2009 | 04:15 PM
TMS Bill's Avatar
TMS Bill
You'll have to pull the shocks. I've taken them out without a compressor (by hanging the axle) but it is easier with one.
Old Apr 2, 2009 | 04:45 PM
Hurley1860's Avatar
Hurley1860
Im going to see if i can rent or borrow a compressor from my work and just get one from the wreakers because they want $102 - $107 for a new pair so i should be able to pick 1 because that is all i need and it will be a fraction of the cost. I love going to the wreakers!!!
Old Apr 2, 2009 | 10:52 PM
olyelr's Avatar
olyelr
Short box regular cab dodges have a wheelbase of 119".
As far as changing coil springs, just remove the shocks, unbolt the sway bar from the frame, and then jack the front of the frame up until the axle droops enough for the coils to fall out.
Old Apr 3, 2009 | 04:23 AM
helms's Avatar
helms
im guessing that they are talking about a 2wd
Old Apr 3, 2009 | 08:27 AM
olyelr's Avatar
olyelr
Well sheit the bed, now that I look at his signature it DOES look like a 2x4.
Oops, disregard my last post. I don't know anything about the 2 wheelers.
