New Cam, Old Engine
Old Apr 3, 2009 | 04:05 PM
2 Marks's Avatar
2 Marks
Default New Cam, Old Engine
Anyone know of potential issues when istalling a hopped up CAM in an engine with 100k+? Interested in a towing CAM... the engine is still strong. Thanks.
Old Apr 3, 2009 | 04:51 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
If you are going with a stock type roller cam (same as factory), then technically, there should be no issues with making the swap unless it's ultra high lift/long duration. However, I did run into some unforseen issues with my cam swap:
1. Be very careful when removing your original cam. The cam bearings are very easily damaged if a cam lobe is allowed to fall on or nick a bearing. Don't kid yourself, it is very easy to do. Even if you get the cam out cleanly, you still might have some bearing errosion/damage. In my case, I either damaged the #4 bearing while removing the cam or it erroded over time. I don't know for sure. In any case, I had to replace the bearing and polish it down to get my replacement cam to fit. Total PITA.
2. You need to take the time to degree-in your new cam. I used the 3-key timing chain set Hughes sells and wound up using the advanced keyway to get the valve timing right.
3. If your lifters need to be replaced, buy a good quality set and be sure to soak them in a quart of engine oil for several hours before you install them. Don't pump them up first like old school. I wound up just rebuilding my factory lifters because there was no play in the rollers and they were not gummed or varnished up. Plus, by comparison with a new set I had, they looked more HD than the replacements.
4. Make sure your pushrods are straight before reusing.
5. If your factory rockers are in good condition, they can be reused. Just my opinion here, but I believe the stockers are much stronger in the fulcrum area than the rollers are. Not dissing the rollers mind you, but in a street level engine (under 6,000 rpm), I don't think they give you any advantage over stock other than looks. Please note all you 1.7 owners with original factory cams, this does not include you.
Old Apr 3, 2009 | 10:34 PM
BlueBeast2's Avatar
BlueBeast2
Rexx will probaby disagree with me but some cams say you should get hardened pushrods. You should also check and make sure they are the right size with your new cam
Old Apr 4, 2009 | 04:43 PM
Rex-TheDOGG
Sounds reasonable to me.
Old Apr 4, 2009 | 07:52 PM
Ugly1's Avatar
Ugly1
Also depending on cam you may wanna consider valve springs. 100K is alot of miles. Sacked springs with higher lift, steeper ramp etc cam will ruin valves and seats real fast.
