Transmission Cooler recommedations needed
Old Apr 5, 2009 | 08:32 PM
Silver_Dodge's Avatar
Silver_Dodge
I agree, bigger is better. I have a Flex-a-lite rated at 32,000 GVW. It made a difference, my gauge does not lie.
Old Apr 5, 2009 | 10:34 PM
hometheaterman's Avatar
hometheaterman
I like my B&M but like said this is covered very often.
Old Apr 7, 2009 | 09:00 PM
jgcox6's Avatar
jgcox6
Ordered the biggest one they got...I am going to be tooo coool! Thanks guys
Old Apr 7, 2009 | 09:14 PM
PurplDodge's Avatar
PurplDodge
I have the cooler that is one size down from Reid's. Mine is rated for 28,000 GVW. Before I removed the check valve, added an external filter, and the cooler, my trans temps were around 180*/190* in 70* weather. After installing ^, My temps hover around 140*/160* in 50* weather.
I would recomend removing the check valve and installing an external filter.
https://dodgeforum.com/forum/2nd-gen...r-install.html
https://dodgeforum.com/forum/2nd-gen...ve-delete.html
Old Apr 7, 2009 | 09:27 PM
DODGEIT105's Avatar
DODGEIT105
I have used coolers with copper tubing in them. I've used them on 4 wheel drive p/u's, and motorhomes and have always had the best luck. They work well and never failed me. I can't recall the brand name of the ones I use but they are out there. What is nice about them is if they spring a leak they can be solder back up as I have seen it done. They need to be flushed good before repairing them but it is possible. I always used more cooler then necessary to give me the extra protection. I also heard that they should be installed in parallel with any other cooler including the one in the radiator tank.
Old Apr 8, 2009 | 06:45 AM
notanexit7's Avatar
notanexit7
god i want to do that check valve thing. after reading that diy though i'm completely and utterly lost with all those fittings and crap. i'm not a mechanic . would a transmission shop be able to do this or is this strictly a do it yourself thing.
Old Apr 8, 2009 | 06:52 AM
PurplDodge's Avatar
PurplDodge
Which one are you reading? Mine only fits the purple trucks!
Old Apr 8, 2009 | 06:55 AM
notanexit7's Avatar
notanexit7
haha, i read both. i shoulda attempted to do this when i replaced the radiator a couple months ago. had to take that hose off anyways.
Old Apr 8, 2009 | 10:53 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
When I finally get around to doing mine (pitiful tax refund), I'm going to plumb it in series (downstream) from the factor rad cooler.
Also, never understood why the check valve is so bad. Is it that much of a flow restriction? Isn't it there to keep the cooling circuit filled with fluid?
Old Apr 8, 2009 | 11:09 AM
PurplDodge's Avatar
PurplDodge
The check valve is there to keep the converter filled with fluid while the truck is sitting for a long time. We remove the check valve because the ball in the check valve can clog up with fluid. If it clogs up, fluid cant get to the cooler, the tranny overheats, and it is toast.
