In response to Moonroof & cust. Stereo system
Old Apr 6, 2009 | 12:25 AM
GoneLikeThaGreen's Avatar
GoneLikeThaGreen
Default In response to Moonroof & cust. Stereo system
So now there is no such thing as a factory moon or sun roof for 2nd gen Rams but I do have a after market moonroof its a waseba and i love it. I found the original reciept for it in the glove box when i bought the truck it was dated 5/18/99 so the original owner had it installed right away. The cost was $950. with install included. I will either have some pics posted up on this thread or if I cant figure it out you can go to my myspace page and check them out http://www.myspace.com/shaunresemius. Im also posting on my stereo system that I have yet to unvail.
Old Apr 6, 2009 | 12:27 AM
GoneLikeThaGreen
<a href="http://viewmorepics.myspace.com/inde...29437951"><img src="http://hotlink.myspacecdn.com/images...4ee02165/m.jpg" alt="" /></a>
Old Apr 6, 2009 | 12:29 AM
GoneLikeThaGreen
ok so as i figured i dont know how to get the pictures to show up in the messages so go check out my myspace page to see them
Old Apr 6, 2009 | 12:41 AM
dodge15004x45.9's Avatar
dodge15004x45.9
There nice.
Old Apr 6, 2009 | 12:54 AM
Laramie1997's Avatar
Laramie1997
Nice, but if you want your photos to show up in a thread like this: Name:  0315091842-03.jpg
You have to go to an image hosting website like www.photobucket.com and get an account there. Once you have the account, just up load your photos. Once that is done, and you have edited the tag page that it will take you to, it should bring you back to a screen like this one: Name:  Untitled-1.jpg
Size:  32.3 KB Ignore the second part of that pic. See where the mouse is? once you roll it over a picture on that page a drop down box will appear and you can copy and paste the image codes into a thread post.
Old Apr 6, 2009 | 01:12 AM
GoneLikeThaGreen
Default Stereo
Ok so as far as my stereo system I put a lot of thought into it before i dove into it. so i started with the Kenwood deck at about $150 installed at best buy for free then i wanted to take up as little space as possible with the sub set up and i dont need to win any competions so i went with a custom 10" enclosure that i found on internet $70 approxmetly had to cut carpet out from beneath it so it would bolt down tight and clear seat. Next the sub they said would fit didnt cause the magnet was to big so I found one that fit and was a better sub anways a 10" Kicker comp. vr $120. Next the hardest part of all mounting the amp on the bottom of the seat holy it sucked but defintly worth it k so there is only a metal bar at top and bottom when seat is tipped up so I cut a slit at the bottom and constructed a piece of wood with metal brackets at top and bottom shoved the top up in between bar and front side of carpet and screwed bottom bracket to the bottom bar sewed seat back up back heavy duty thread and a c shaped needle mounted 400 watt Niche audio amp about $200 and ran wires nice, mounted remote gain for it on dash under deck wires hidden also. Wiring kit for amp $50. Recently added a 1 farad rockford fasgate capacitor $150. Easiest and best spot was to mount it on floor under amp make sure to leave about a 1/2 to 1 inch of extra space between amp and cap so when the seat is down with someone sitting on it, it wont touch and i found the best way to mount it was by making 2 small holes in carpet only near each mounting screw hole cause i could not find srews small enough and long enough to make it to the metal so i used black zip ties (use small alan wrench to move insulation and make clear path to get ties through) Mounted new cerwin vega 6x9's $150 in front doors (there will be a thing attached to factory speakers with quite a few wires going in and out i un bolted it from speaker and kept it hooked up used same wires to go to speaker and zip tie the wierd thing inside door torwards front end on some heavy duty wires so not to rattle or get in way of window track) Rear doors 5 1/4 infinty refrences $70 simple enough you may want to add some bass blockers close to the speakers in doors i didnt but if your going to do it the first time those door panels arent fun to play with i wish i would have because i think the new speakers are already partially blown. so thats kenwood deck $150, Custom 10" box $70, 10" Kicker comp. vr $120, 400 watt Niche audio amp $200, Wiring kit for amp $50, 1 farad rockford fasgate capacitor $150, cerwin vega 6x9's $150, 5 1/4 infinty refrences $70. Total $960 Go check the pic out on my myspace http://www.myspace.com/shaunresemius any other question just ask but i think i covered it all hope this helps you guys out with upgrade your stereos
Old Apr 6, 2009 | 01:14 AM
dakotas ram's Avatar
dakotas ram
the front of your truck looks killer.....i like your pipes too, what exhaust are u runnin?
Old Apr 6, 2009 | 01:21 AM
GoneLikeThaGreen
Dynamax or dynamat cant remember
GoneLikeThaGreen
Thanks for the compliment as well
Old Apr 6, 2009 | 01:24 AM
GoneLikeThaGreen
I just added smoked license plate covers really brings it all together I'll have to get some new pics up
