tranny issues
Old Apr 10, 2009 | 06:09 PM
blake258's Avatar
blake258
Default tranny issues
I did a bit of searching, but I really didn't find anything definitive.
the problems Im experiencing are:
reverse works until you give it gas
Drive works but will slip then "catch". this is only if I give it a bit of gas to begin with, if I get on it REAL slow, its fine
1 & 2 gears (on staulk) work fine
shifting points seem strange, like it wont downshift or upshift, but only sometimes.
4WD light is on, even though its not in 4WD (i dont think) and the Brake light is on even though thte parking brake isnt set, and the ABS light is on.
I just picked this truck up for real cheap and expecting to put some money into it, but as little as possible. TIA for your help, I know what forums are like, and I am a noob to this one.
Old Apr 10, 2009 | 09:14 PM
JackJ's Avatar
JackJ
First off, welcome.
Then, check the tranny fluid if it low or to high it will screw up the shifting (also what is "staulk").
Then, check the codes by taking it in somwhere, Pep-Boys will do it for free. As for the 4wd light, there is a way to check it, if I remember right the only way the 4wd light will come on is if the vacum is engaged.
Old Apr 11, 2009 | 02:11 AM
ttaylor's Avatar
ttaylor
Dont know if this will help,but my 99 ram had the abs,brake,and check engine lights on and when I replaced the speed sensor in the trany and the rear end they all went away.
Old Apr 12, 2009 | 09:13 AM
blake258's Avatar
blake258
hmm, my CEL is not illuminated, Could It really only be that the fluid is old/too high/too low for the tranny issues? any good sources for tranny filters and pan gaskets and fluid?
Old Apr 12, 2009 | 09:38 AM
hutch1973's Avatar
hutch1973
What year truck do you have? Have you just gone through and checked all fluid levels? How many miles on the truck? Also, how much have you driven it since buying it?
Old Apr 12, 2009 | 03:09 PM
dsertdog56's Avatar
dsertdog56
I would say since you have lamps illuminated you have sensor/pcm issue. I don't know the year of your ram, which also makes diagnosis dicey on the internet, but if you have a 46RE which is controled by electronics, your speed sensor may be the issue. You can't always go by a CEL, or wait for the fault to cycle through several start run cycles before tripping your code. I believe you can test the speed sensor and that may be a good place to start.
It could be a faulty module as well.
Are far as mechanics go, if your fluid is old, sludgy, or burnt, you could have several issues. High mileage is a factor in the mechanical destruction of these trannies even with the best maintenance. At the risk of being long winded, other factors/causes could be (in no order) plugged filter, check valve, cooler, faulty pressure switch (which controls the fluid flow), burnt bands/drums, and even your TPS.
