Rear End Additive?
Old Apr 12, 2009 | 05:33 PM
Relex's Avatar
Relex
Default Rear End Additive?
My friend told me about this additive (I forget the name) but it helps both wheels lock in more. Is there really additive that does this?
Old Apr 12, 2009 | 05:39 PM
dhvaughan's Avatar
dhvaughan
no, not really.
what he was talking about is a 'friction modifier' that is required for limited slip differentials. its required for the clutches. its in the parts stores in little 6-8 oz bottles located next to the rear end oil.
Old Apr 12, 2009 | 10:24 PM
armydodge2500's Avatar
armydodge2500
Relex,
When I changed the the rear Dif oil in my truck I went to Autozone and got some Limited Slip additive. It comes in 7 ounce tubes. Supposedly makes the gear oil work better. The stuff cost about 8 bucks a tube. Hope this info helps!
Old Apr 13, 2009 | 05:06 AM
mikey0469's Avatar
mikey0469
does your friend know if you have a limited slip differential or not? but regardless of that....lucas oil has a product 80-90 wt i run in my differentials both for limited slips, lockers, or just a stock open carrier diff.
