5 in coil spacers
Old Jun 2, 2009 | 06:15 PM
aj99's Avatar
aj99
well here is the reasoning behind it. I have my Jeep that i use for off road purposes. My truck is just for around town and work. It doesnt go off road at all except for my back pasture.
Old Jun 2, 2009 | 06:18 PM
PurplDodge's Avatar
PurplDodge
So, that is why you want to go cheap? It is your daily driver?
Old Jun 2, 2009 | 07:00 PM
aj99's Avatar
aj99
ya i usually drive it every day unless my jeep is running then i drive that more. but i dont see a reason to spend 800 or more dollars on a lift from my truck when its not going to be used. But i also dont see the point of a body lift. I refuse to get a body lift. So i want to do a cheap lift for my dodge. I have 33s on it right now and it rubs a little. But i want to lift it about 5 to 7 inches. I was thinking of doing the spacers, and going to the JY and getting the coils out of a 2500 and throwing them up front with the spacer and then doing shackles and blocks in the rear.
Old Jun 2, 2009 | 07:02 PM
PurplDodge's Avatar
PurplDodge
What tires are you looking at running?
Old Jun 2, 2009 | 07:10 PM
aj99's Avatar
aj99
well i want to go to 35s because i have a lot of those laying in my shed that are in decent shape and i figured i could use those for my dodge instead of having to buy new 33s. Plus i can get 35s for basically free. A buddy has a sponsorship through a local tire shop and he uses 35s on his prerunner so i get all the used ones.
