What differential do I have?
Old Apr 15, 2009 | 04:08 PM
jphuffs's Avatar
jphuffs
Default What differential do I have?
I have a '96 2500 Ram with a Cummings Diesel engine. The differential is a 4.10, limited slip (From the original window sticker). Without crawling under the truck, can someone tell me what differential I have? The truck manual says that the lubricant type and the fill level are different if I have a Chrysler differential or one of three different Dana differentials.
Old Apr 15, 2009 | 04:15 PM
Cereal Killer's Avatar
Cereal Killer
It's a dana 70.
If it's a 4x4 you have a dana 60 in the front. It'd be a good idea to do them both.
Old Apr 15, 2009 | 06:18 PM
TMS Bill's Avatar
TMS Bill
You sure ??? Thought the 3500's got the D70/80 (single/dual) ... the 2500's got a D60.
Doesn't matter ... if it's a CTD 3/4 ton ... it's a Dana/Spicer.
Old Apr 15, 2009 | 06:47 PM
Cereal Killer
The 2500s with the 5.9 V-8 had a dana 60 in the rear, but the V-10s and the cummins had the dana 70 in the rear.
There was no single 3500 2nd gens. All the 3500s were duallys and they got the dana 80s
Old Apr 15, 2009 | 08:53 PM
runyonracing's Avatar
runyonracing
My brother just did his truck 2nd Gen 3/4 ton with V-10 and it had the Dana 60 in it.
Old Apr 15, 2009 | 09:44 PM
Cereal Killer
Really? Damn I may be misinformed. Sorry about that. Maybe it was just the diesels that had the dana 70 in the rear end. I thought for sure the V-10s did too.
Edit - Maybe I'm wrong about this, but I thought the 2500s with the v-10 or cummins had a dana 70 rearend if they had an automatic transmission, and a dana 80 if they were a manual transmission, and all the 3500s had a dana 80 in them regardless of the engine.
Old Apr 16, 2009 | 09:36 AM
jphuffs's Avatar
jphuffs
Thanks a lot. That helps. One more question. Do I need a new gasket to change the oil in the differential? Dodge part?
Old Apr 16, 2009 | 10:13 AM
Kraiger's Avatar
Kraiger
No just use silicon or a product that you can find at autozone its called the right stuff. its made by permetex Thats what i do.
Old Apr 16, 2009 | 11:35 AM
xskylinedx's Avatar
xskylinedx
If its a dana it should have a two digit number on the differential. Older 2nd gen 2500's did
get the 9.25 rear but that may be just with the V8 3/4 ton.
Old Apr 16, 2009 | 11:43 AM
Cereal Killer
Yeah the 94, 95, and possibly 96 Light duty 2500s had 8 lug dana 44s up front, and 8 lug 9.25s in the rear, but the that was only with the 5.9 v-8 option.
As for the gasket, get yourself some RVT sealant. I used the black kind. I believe it had the highest resistance to heat. Not sure if it matters, but mine has never leaked.
