Rev limiter
Old Mar 8, 2005 | 09:13 PM
Superman750's Avatar
Superman750
Default Rev limiter
Hey guys... first off I have a 2001 Ram 1500 2wd 5.2L. I have NO off the line torque. Yesterday I was almost beaten by a minivan, and dont say it was the driving. I was told by a friend that there is a way to disconnect the rev limiter, or even install a switch to temporarily disconnect it. I am assuming that the R.L. is connected to the tranny somewhere. Does anyone know where this wire/plug is? Any help would be greatly appreciated.
Dan
Old Mar 9, 2005 | 01:19 AM
horatio102's Avatar
horatio102
Default RE: Rev limiter
Why do you want to disconnect the rev limiter? Are you going to try doing 6000 rpm neutral drops to smoke the tires off the line better? The stock cam doesn't make power way up high, so you could possibly see no gains whatsoever, with the downside being potential valve float.
Old Mar 10, 2005 | 08:39 PM
440Duster's Avatar
440Duster
My 73 plymouth duster had the same exact problem. I ended up unbolting the original 225 slant six from the starter motor and replacing it with a 440 8-barrel. Off-the-line torque really increased!!!!!
Old Mar 10, 2005 | 10:27 PM
stic's Avatar
stic
id imagine it would.
