Front driveshaft angle
Old Apr 20, 2009 | 06:49 PM
postie1686's Avatar
postie1686
Default Front driveshaft angle
Hey guys im new on here but i have a question and i hope some one knows.
this past weekend i put a lift in my 2001 ram and its all there but the angle on my front driveshaft where it meets the transfer case is tight and im afraid when front suspenion drops im afraid it will cause that shaft bind at the knuckle. so my uestion is does anyone know if or where i could find a higher angle shaft or maybe just the joint?
Old Apr 20, 2009 | 08:43 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Bump.
Look into a tcase drop kit. How much lift?
Old Apr 20, 2009 | 09:57 PM
dsertdog56's Avatar
dsertdog56
Welcome to DF...try here.
http://www.arizonadrivelines.com/Dri...ng_splines.htm
This is good stuff!
Old Apr 21, 2009 | 01:41 AM
postie1686's Avatar
postie1686
its only a rough contry 5" but it looks like it could be trouble. ill try and take a picture of it tomarow and see what you guys think
Old Apr 21, 2009 | 10:01 AM
Aubrey's Avatar
Aubrey
You shouldn't need to for a 5". Maybe if it's a regular cab short bed but more than likely you will not need to worry about it. If you still feel you need to, instead of buying a custom shaft, clearance it slightly. You can find information on clearancing on SkyJacker or Superlift's websites. Can't remember which.
Old Apr 21, 2009 | 10:08 AM
olyelr's Avatar
olyelr
With 5-7" of lift the front shaft is usually just fine.
There are a few things can do. You can get an indexing ring that will rotate the transfer cases front shaft output down (Skyjackers 7" kit comes with one, as well as the new cross member to accomidate it), you can grind around the upper double cardan joint (the Fabtech kit comes with directions on how/where to do this), or you can purchase an expensive new driveshaft. But, you should be just fine.
Just jack the front of the truck up until the axle is fully drooped and reach under and spin the front shaft... if it binds then you should do something about it.
You could also get limiting straps to prevent the axle from fully drooping, but whats the fun in that.
Old Apr 21, 2009 | 11:13 AM
postie1686's Avatar
postie1686
well maybe ill wait a bit yet and see where it rides when everything settles in. but thank you all for the help and ideas
