2000 RR Spindle Threads Stripped
Old Apr 21, 2009 | 12:39 AM
KY2500's Avatar
KY2500
Default 2000 RR Spindle Threads Stripped
The story is I purchased a 2000 Ram 2500 4x4 last fall and when the temps here started dropping a metal brake line burst. I replaced every line, most with cunnifer except for the rear axle lines where I used OEM. Anyway, while fixing this I noticed a RR axle seal leak. This is where I open up a can of worms as the 2 9/16 inch locknut was loose at first, but midway off became a bear. I changed the seal cleaned the hub, and bearings real nice, packed them full of grease. I bought a new locknut, and with my fingers crossed I hoped it would thread. Nope, the spindle threads are stripped at halfway. I broke my 2 9/16 socket and a 2 1/2 trying to get it to thread. Anybody changed a Dana 60 rear spindle that could shead some light? Are they pressed into the tube and if so, how do do get'em out? Thanks in advance.
Old May 4, 2009 | 01:00 PM
KY2500's Avatar
KY2500
Finally got around to finishing this project. I used a die kit(KASTAR 2577) to rethread the spindle(2"). Very happy with the result, the new nylock hub nut threaded perfectly. I would recommend to anyone taking the hub nut loose to clean the threads with brake cleaner before removing the nut. I think I could have saved myself $110.
