Out with the old...
Old Apr 22, 2009 | 09:28 PM
Rockyhigh360's Avatar
Rockyhigh360
Default Out with the old...
So the old Trans is out, and the new mega viper sits under the truck waiting to be thrown in. I think my check valve in the cooler return line is to blame. It was clogged until I shook it, then it spewed out burnt fluid into my face as I looked into it. A temp sensor would have me known the valve was clogged.
Now I need to gut my cat, clean all the grease and gunk off hoses, linkage, wires, ect. Also need to drop the flexplate (flywheel) and give it a good sand and clean. Then blow the cooler lines out with air and maybe a new Trans cooler. I heard the old ones can be deceiving and flow cold but not hot. Oh, new U joints while the drive shafts are out.
Attachment 3878
Attachment 3879
Attachment 3880
Old Apr 22, 2009 | 09:35 PM
xskylinedx's Avatar
xskylinedx
I think your gonna like it, I like mine. What setting did you go with for the valve body?
Old Apr 22, 2009 | 09:36 PM
hutch1973's Avatar
hutch1973
Prolly need to wash your face too.
Seriously, good luck though. Curious how you like the trans when all is said and done.
Old Apr 22, 2009 | 09:45 PM
Rockyhigh360
Didn't go with the street shift, opted for the tow shift kit and the 2k stall. Also larger trans pan. Did you replace your cooler?
Old Apr 22, 2009 | 10:01 PM
xskylinedx's Avatar
xskylinedx
I went with the street strip. I snagged the flex-a-lite cooler with fan and thermal sensor.
Old Apr 22, 2009 | 10:07 PM
PurplDodge's Avatar
PurplDodge
I wish those damn PATC trannys dont cost as much as the whole freaking truck or I would have one.
Old Apr 23, 2009 | 01:16 AM
dhvaughan's Avatar
dhvaughan
hey, take a look at the freeze plugs on the back of the block and heads while you got everything out. several people have reported leaks from them lately.
mega viper sounds impressive. if you get a chance post some DIY info on the swap.
