front hub nut
Old Apr 26, 2009 | 11:27 AM
lv360ram's Avatar
lv360ram
Default front hub nut
the nut for my front hub, wheel bearing assembly says "do not reuse nut"
is that because it is a lock nut and removing it and retightening it will reduce it's lockability?
Old Apr 26, 2009 | 11:41 AM
zman17's Avatar
zman17
Retired Moderator - RIP
If it's not a castle nut with a cotter pin, reusing it is not recommended. But should be okay for a few days while you get a new one. Just be careful.
Old Apr 26, 2009 | 10:45 PM
lv360ram's Avatar
lv360ram
I removed the nut and saw it is a nylock. I have been using nylocks on various things for many years and the more the nylock is tightened and loosened, the less locking grip.
Of course I reused it.
the nylon still had some grip but I used thread lock compound, so I don't think it will come loose.
