Wheel upgrade
Old Apr 26, 2009 | 07:37 PM
cccharmont's Avatar
cccharmont
Default Wheel upgrade
I have a 98 Dodge Ram 2WD and what to upgrade the wheels to 20's. The front rotors won't allow that. Is there any suggestion on how I can make this happen? Can I change rotors and wheel assemble?
Old Apr 26, 2009 | 08:01 PM
dodge15004x45.9's Avatar
dodge15004x45.9
They should what is hitting. I have a hard to seeing the break rotors getting in the way of a 20" wheel the fit fine with my 16X8. If anything I can see the tire being to big and rubbing.
Old Apr 26, 2009 | 08:29 PM
EndIsNear's Avatar
EndIsNear
I wonder if it's the backspacing?
Old Apr 26, 2009 | 08:31 PM
2damnyankee's Avatar
2damnyankee
it depends on what back spacing you got on the wheels it self. if the inside of the wheels are hitting the rotors and calipers you may need to get spacers so they stick out alittle to clear the rotors and calipers
Old Apr 28, 2009 | 11:28 PM
cccharmont's Avatar
cccharmont
Thanks a million!!! You are right about the spacer/adapter. I did a little research and that's what I found out, again THANKS.
Old Apr 29, 2009 | 12:02 AM
engineblock's Avatar
engineblock
if the 20s are the rims of the 3rd gen ram thn you do need the spacer, i had bought them and i put a 1/2 inch spacer and they fit perfectly, i put them all around so they could all match
