2000 with 5.9 and 110K
Found a pickup with the Auto 5.9L and 110K miles for 3500 bucks, good deal? Or would the 360 **** on me soon? I had a 89 Ramcharger with a 318 that still won't die, but is that the case ten years later?
yeah, if transmission shifts ok both when cold and warmed up, and its 4wd, i'd give 3500. it'll be pretty much the same as your 01, except will have a lighter duty drive line. if the transmissions crapped out i wouldn't give but 1000.
i'd consider a compression test, and tell the owner up front - if the spark plug breaks off or strips - its yours, as is. these trucks have a little tendency to develp cracked heads, which is another very expensive repair.
other common problems are sloppy steering and front end, plenum leak, cracked dash, heater core. everything else is just normal.
