View Poll Results: what is the problem with the no marker lights?
Bad Switch?
3
60.00%
Bad Ground?
2
40.00%
Voters: 5. You may not vote on this poll
2001 no marker/tail lights
Old May 1, 2009 | 12:38 AM
crazy1snow's Avatar
crazy1snow
Default 2001 no marker/tail lights
I've got an issue with having no dash lights, no marker lights, when I turn on the headlights or even just the marker light middle setting on the dial.
Any ideas? Checked the fuses didn't see any blown out, could it just be as simple as the switch has gone dead? Anyone have that happen on an 01 1500 360 slt gasser?
Old May 1, 2009 | 12:42 AM
Laramie1997's Avatar
Laramie1997
I say switch, but check the fuses again. The label for the fuse is titled real funky...
Old May 1, 2009 | 02:14 AM
ophidia's Avatar
ophidia
When I had that happen it was a loose ground + a chewed through positive lead grounding out. Quick fix with some black tape and it's all good.
Last edited by ophidia; May 1, 2009 at 02:17 AM. Reason: Mispellings due to being moderately inebriated
Old May 1, 2009 | 11:35 PM
95MaroonMonster's Avatar
95MaroonMonster
had that problem in my 95, a wire was rubbing the frame, and shorted out, black tape fixed it
