Problem with my Ram
ok so I was on here, 'round 'bout January looking for a 2nd Gen. Ram to buy, someone Recommened Craigslist, so I used it, Found a truck, so I bought it. :)
I bought the Truck 2 weeks ago, come Tuesday, only has 97,000 Miles, It's the 5.2 318, and it is a 4x4. ok I havnt gotten it Registered yet, so It's been sitting in my Driveway this whole time. I drove it over 100 Miles home, Perfect, Flawless, no Problems. I went out about 5 minutes ago to Move the Truck, and I put it in drive, Drove about 45 Feet give or Take, Then I put it in Reverse, Well when I did that It made a weird a Wierd Whining Noise, I drove it in Reverse back to where I had it, went to Put it back into Drive and the Truck just Dies. I started it back up to see if it would Fire. It started right back up, but I didn't take it out of Park. Does anyone know what the Problem could be? |
let it idle in neutral for awhile and warm up.
for some stupid reason, the transmission pump doesn't run in park. it'll probably quiet down. edit - by sitting for so long, all the fluid may have drained back. mine whines a little in reverse when cold. its sort of normal. a minute or so in neutral helps it. welcome. |
but that wouldnt Cause it to die when I took it from Reverse to Drive though, would it?
Even after it died, I started it back up in Park, The Motor Sounded different at idle and When I reved it. |
