mixture problem
Old Mar 11, 2005 | 03:27 AM
jordan191's Avatar
jordan191
Default mixture problem
My 1996 ram 1500 with the 360 is running so rich i can smell unburned gas and it only gets 6 mpg. I hear there is a coolant temp sensor that doesnt let the computer control the mixture until the truck is warm. Does anyone know if this truck has one?
By the way I have replaced Cap, Rotor, Plugs, Wires, O2 sensors, Plenum gasket, Air filter, and PCV valve trying to get more gas mileage out of it. (went from 4mpg to 6 mpg)
But still when i look in the tailpipe it is covered in black soot and the truck always smells rich.
Old Mar 11, 2005 | 03:29 AM
jordan191's Avatar
jordan191
Default RE: mixture problem
Oh I also forgot to say that my temp gauge in the truck is working, I would figure the sensor for the computer uses the same one for the gauge but maybe there is a separate one? hopefully because i am running out of ideas. PLEASE HELP!!!!!!!
Old Mar 11, 2005 | 01:44 PM
steve05ram360's Avatar
steve05ram360
check your cat, it could be plugged. measure the inlet & outlet temps, output should be hotter by at least 50 deg f for the cat to be working properly (warmed up of course).
swap out your IAT sensor, mounted up by the #2 cylinder and check the wiring. your motor sounds like it's in open loop mode. what temp t-stat do you have in there?
Check for any engine codes
Old Mar 12, 2005 | 05:45 PM
jordan191's Avatar
jordan191
It has a brand new cat, Its the stock t-stat which i think is 200 but im not sure.
Changing the IAT sensor was my next guess so I will most likely do that
Old Mar 12, 2005 | 09:49 PM
jordan191's Avatar
jordan191
ok so I changed the IAT sensor and still runs rich
Any more suggestions?
Old Mar 13, 2005 | 04:12 PM
440Duster's Avatar
440Duster
Have you checked the O2 sensor(s)? When they fail, the computer will run in limp-in mode causing the engine to run rich. Usually when this happens it will stumble on accel from idle. Have you pulled any codes?
Old Mar 14, 2005 | 03:08 AM
jordan191's Avatar
jordan191
O2 sensors are also new (engine codes were right bank O2 sensor failure, so i changed all the O2 sensors, also there was a system too lean engine code and i traced it to the plenum gasket and replaced that as well)
As you can see I have done almost everything anyone can think of. This is a very confusing problem
