Changing the O2 Sensor...
Old May 3, 2009 | 08:22 PM
Gmann1956's Avatar
Gmann1956
Default Changing the O2 Sensor...
My '01 Ram 5.2L threw a code P0138, it looks to be the O2 Sensor after the cat. I crawled under there today, rain and all, to see how easy or difficult it would be. Getting the old one out looks pretty easy. I tried following the wire to see where it was plugged in, but it appeared to be somewhere up on top of the tranny housing. Does that sound right? If so , I may have to do the plug in by feel. I'm going to give it a shot tomorrow if it ever stops raining.
Old May 3, 2009 | 08:25 PM
PurplDodge's Avatar
PurplDodge
The plug is usually on top of the tranny.
Old May 3, 2009 | 08:30 PM
pdavis53's Avatar
pdavis53
Yes, the plug is on top of the Tranny. I just replaced mine and it was fairly easy. just make sure to be patient with the clip. It is a two part, I broke the first part but the second part has kept it together just fine. Also just pull the wire a little and it should give you some more room.
Old May 3, 2009 | 08:44 PM
Gmann1956's Avatar
Gmann1956
Looks like the plug part is definitely going to be by feel, up there on the tranny
