Swapping out dashes
Old May 4, 2009 | 12:47 AM
aj99's Avatar
aj99
Default Swapping out dashes
I was wondering if i could swap a dash out of a 98 into a 97? I like the 98+ dashes a lot better than my 97. I am not worried about the electrical i can figure that out but i was wondering if the bolt pattern was the same
Old May 4, 2009 | 12:05 PM
EndIsNear's Avatar
EndIsNear
I seriously doubt it. The bolts below the windshield may be the same, but the front is likely to be all different due to the shape. You would however, have to replace everything like the instrument cluster, climate controls, etc. If it was possible (and I'm not saying it's not) then it would be a hell of a job. Goodluck!
Old May 4, 2009 | 01:50 PM
aj99's Avatar
aj99
I know the shape is different. I was thinking of using everything from the firewall back that mounts the dash to the firewall. I am still trying to find out if anyone has thought of it or has done it yet? If it works out ill do a build page on it.
Old May 4, 2009 | 02:05 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Just get a cover!
Old May 5, 2009 | 06:29 PM
aj99's Avatar
aj99
What do you mean a cover? I dont want to have the same dash i want the 98+ dash. I like the lines a lot better than the 97s
Old May 5, 2009 | 08:22 PM
EndIsNear's Avatar
EndIsNear
Man, it looks like your on your own. I have no idea if that swap will work or not. Go get a dashboard from a junkyard and just try it. If it does work, it would be a bada$$ write up.
Old May 5, 2009 | 10:55 PM
dodge15004x45.9
It sits on top of your dash to cover all the cracks.
Old May 7, 2009 | 03:57 AM
aj99's Avatar
aj99
ya mines not cracked. I just dont like the style of it. I want the style of the 98+
