Figured out my check gage light.....NO OIL IN MOTOR!!!
Old May 4, 2009 | 05:46 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I check the fluid levels in all my vehicles every week. No and's, if's or but's about it. Differentials get checked at every oil change.
Old May 4, 2009 | 10:58 PM
dhvaughan's Avatar
dhvaughan
the plenum gasket is probably leaking again. the steel plate, too short holes, and too long bolts all combine to be a really $hitty setup. replace the steel plate with a hughes plate.
disappearing coolant could be just water pump going bad or a leaking radiator, hose or clamp. if its head gasket you'll see steam, or white smoke, or water in oil.
Old May 5, 2009 | 06:37 AM
hovie's Avatar
hovie
I figured it was the steel plate from the plenum. Will keep you all informed on what I find out.
Old May 5, 2009 | 10:43 AM
zman17's Avatar
zman17
Here is one way of checking it, http://dodgeram.info/tsb/2000/09-05-00.htm
Old May 5, 2009 | 10:52 AM
mopar1973man's Avatar
mopar1973man
Agreed! I check all fluids (Oil, Coolant, Brake fluid, PS fluid) once a week. The under side stuff like (Diff's, transfer case, and manual trans) I check once a month. No if's and's or but's here...
Old May 5, 2009 | 03:46 PM
lastrights's Avatar
lastrights
yeah keep us updated hope evreything goes well !!
