abs brakes need help please
Old May 5, 2009 | 08:14 PM
jerry1horse2's Avatar
jerry1horse2
Default abs brakes need help please
01 2500 dodge diesel. I need to know if I have 4 wheel abs brakes or 2 wheel. does anyone know or know how I can tell? I have to replace wheel hub assembly and need to know about the abs system. Thanks in advance.
Old May 5, 2009 | 08:21 PM
dhvaughan's Avatar
dhvaughan
remove front tire and look around the bearing hub and steering knuckle. you'll find a brake hose going to the caliper. if you additionally find a wire going to the hub or knuckle, then you have front abs.
rear abs is standard.
