Overheating
Old May 14, 2009 | 09:04 PM
  #21
J415's Avatar
J415
Originally Posted by LegendKiller89
J415: Yup the radiator was clogged, I hope that you are able to get your rig fixed soon.
Thanks Mopar for the advice I appreciate it.
Thanks for the reply. Another quick question, when you were having your coolant problems, did you ever have any problems with building up pressure?
Old May 14, 2009 | 09:15 PM
  #22
LegendKiller89's Avatar
LegendKiller89
Nope not really. Only problem I did have was when I first replaced the t-stat the hose got hard but once the t-stat opened it went soft and never had another problem. Hope that helps...
Old Jun 1, 2010 | 02:00 PM
  #23
judsky's Avatar
judsky
Default over heating
ok so i got the same problem legendkiller does ...when i bought the pickup i lookeed like it hada new water pump put in...and on the way home it was running right at 200 and then the bottom radiator hose blew and we got that replaced but then on the way home it was over heating hada stop and let cool and then got home..then we replaced the top hose and the thermostat and the clutch fan and it would run at 200 for a few minutes but then gradully get to 250 and coolant was boiling outa the coolant resevore and no idk wat 2 do any ideas or advice will help!!
Old Jun 1, 2010 | 03:14 PM
  #24
GeorgiaDodge's Avatar
GeorgiaDodge
i ran a descaler throught my system and completly flushe everything, i thought it was the water pump but luckily the descaler and flush fixed it with out spending all the time and money on a water pump
Old Jun 2, 2010 | 02:04 PM
  #25
judsky's Avatar
judsky
yea i just flushed my radiator last night and ther was alota build up and crap in ther and she runs at 200 just beutiful so legend try flushing your radiator a few times tiping it upside down and right side up and havin water run threw it..it worked for my dodge hope it works for u hava good 1..
