Reverse wire in dash
Old May 8, 2009 | 09:13 AM
tresvatos's Avatar
tresvatos
Default Reverse wire in dash
Does anyone know what clor the reverse wire is that activates revers lights under dash, or in steering column. I need to find a wire to trigger a relay for two add on revers lights..
Thanks
Old May 8, 2009 | 09:48 AM
mopar1973man's Avatar
mopar1973man
Kind of like this...
I just tapped the the wire in the left rear taillight and got my power from the +12V trailer light lead. Then added a switch on my overhead console for FORCED ON lighting for trailer hookup...
Old May 8, 2009 | 11:40 AM
pcfixerpro's Avatar
pcfixerpro
I have never seen lights mounted like that before but I imagine they do the trick Nice diagram for the relay hookup.
On a side note... mopar1973man, do you really have a 42RE in your 96 ram? (look at your sig)
Old May 8, 2009 | 12:46 PM
mopar1973man
Here you go again...
Overhead console (Fog lamps, Reverse lights, and red emergency light)
As for th 42RE I'm pretty sure about it... I had looked up a part for a while back and thats what I got from the look up... (Tryin' to remember!)
Old May 8, 2009 | 03:06 PM
PurplDodge's Avatar
PurplDodge
IDK about the one in the dash, but the one in the rear is purple.
Old May 8, 2009 | 05:01 PM
mopar1973man
This might help this is out of the 2001 Dodge FSM book...
Old May 8, 2009 | 07:22 PM
dhvaughan's Avatar
dhvaughan
tap the backup light in the tailight, to either operate a relay (preferred) or directly power the lights (not the best way). i got a couple of cheap little lights from northern tool which mounted very neatly to the receiver hitch.
https://dodgeforum.com/forum/2nd-gen...installed.html
