The computer's wrong...
Old May 8, 2009 | 07:20 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Default The computer's wrong...
Hi, y'all, but I was sobbing over having to replace my bald tires with tiny original used sized ones, and thought I'd ask a question to forget my sorrow for a moment. As some of you know, I swapped cabs a while back. The donor cab had the overhead computer whilst mine did not. But now, It does! However, my average mpg says around 20 - 22 mpg, while the pump says 13 - 15 (the nearest I can figure, anyway.) The donor had a 5.9, and mine has a 5.2. Is there any simple, easy way to fix this? I recently checked my vacuum, and it hovered around 15 inches of mercury, if this matters or not.... Thanks!! (wait, 265's... sob....)
Old May 8, 2009 | 07:50 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The overhead lies anyway, you need to do your MPG the old fashioned way.
Old May 8, 2009 | 07:53 PM
aim4squirrels's Avatar
aim4squirrels
+1 on that! the lie-o-meter is B/S.
It's going off of PCM data anyway so you need not have it reprogrammed, it's getting the correct info.
Old May 8, 2009 | 08:06 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Don't for get you put a bigger motor in your truck, and A diff cab as well.
Old May 9, 2009 | 10:11 AM
Sheriff420's Avatar
Sheriff420
265's? i had 285 70 17 bfg all terrains and had to drop back to 255's because they were 100$ used vs 800 for the ones i had so i feel your pain, being broke sucks.
Old May 9, 2009 | 11:10 AM
johnnyrocket5363
Well, is there some reason the PCM thinks I'm getting better MPG's? I keep wondering if there's something I forgot to tune, and my fuel economy is suffering for it... Thanks for your sympathy, Sherrif!
Old May 9, 2009 | 02:03 PM
Laramie1997's Avatar
Laramie1997
All of the MPG readouts on Dodge trucks are inaccurate. 2nd gen, 3rd gen, and 4th gen.
They just give you a very rough estimate.
Hell even the Ford and GM MPG's are off.
Old May 9, 2009 | 02:08 PM
Cereal Killer's Avatar
Cereal Killer
If you're hand calculating 13-15mpg then I doubt you forgot to tune anything. That's average for these trucks.
