Lubricants questions
Old May 12, 2009 | 09:18 PM
Miami_Son's Avatar
Miami_Son
Default Lubricants questions
Looking over the Chrysler specs for things like tranny oil and diff lube I see these goofy numbers and stuff. That's great, if I want to buy the stuff from them, but what does it translate to if I want to get it from my local auto parts store? There's warnings about using the right stuff, especially in the tranny, but how do you know what is right? I have yet to see a bottle of tranny oil marked "ATF +4" from any manufacturer. And where do you get those little bottles of "friction modifier" that the no-slip diff I have requires? Does that stuff mix with synthetic gear lube?
Old May 12, 2009 | 09:23 PM
PurplDodge's Avatar
PurplDodge
My local AutoZone, Advance, and Walmart all carry ATF+4. Don't worry about getting the cheaper fluids(such as SuperTech, Advance, or Coastal), they are all the same thing. The Friction Modifier should be where the gear oils are.
Old May 12, 2009 | 09:27 PM
dukhunter's Avatar
dukhunter
Atf +4 is synthetic. personal i run royal purple in my diffs, and engine. tranny i use amsoil syntheitic. i have had good luck with this combo on all of my vehicals
Old May 12, 2009 | 09:35 PM
BigRedRam95's Avatar
BigRedRam95
Advance auto and coastal are the same. castal makes advance auto atf+4
Old May 12, 2009 | 09:45 PM
PurplDodge's Avatar
PurplDodge
They ALL ARE THE SAME!! So buy the cheapest ATF+4 you can find!
http://www.centerforqa.com/licensedatf4brands.html
Old May 12, 2009 | 10:00 PM
Cereal Killer's Avatar
Cereal Killer
All transmission fluid is synthetic...
But I have heard good stuff about all amsoil and royal purple products.
Old May 12, 2009 | 10:24 PM
dhvaughan's Avatar
dhvaughan
dexron/mercon and ford type F are not synthetic.
all ATF+4 is synthetic.
Old May 12, 2009 | 10:32 PM
Miami_Son's Avatar
Miami_Son
Interesting. I don't see Amsoil on that list.
Old May 12, 2009 | 10:37 PM
PurplDodge's Avatar
PurplDodge
That is because Amsoil is different.....In a good way. Amsoil excedes the requirements of ATF+4. The reason they cannot be on that list is because Amsoil is a different blend. I have never heard ANY bad thing about using Amsoil in your transmission. I have only heard the best.
Old May 13, 2009 | 01:41 AM
dakotas ram's Avatar
dakotas ram
just because it is a liscensed atf+4 why does that make them all the same?......i mean not all 5w-30 motor oil is the same
