timing adjustment
Old May 13, 2009 | 09:57 PM
ztomtog2's Avatar
ztomtog2
Default timing adjustment
how can you adjust the ignition timing on a 99 ram with 5.2 v8. and which way should it be adjusted for more hp?
Old May 13, 2009 | 10:08 PM
dodgeram07's Avatar
dodgeram07
cps mod,,, advance the timing for alittle more power it the uper rpms
Old May 13, 2009 | 10:19 PM
ztomtog2's Avatar
ztomtog2
will this effect the low end any?
Old May 14, 2009 | 09:18 AM
ICEMAN_CH's Avatar
ICEMAN_CH
No it will not affect low end. By advancing the timing the engine might start pinging at high RPM. This can be made worse by to much load or sparkplugs that are to hot. So if you do the mod drive with you radio off for a while and really listen to the motor. IF you hear pinging there is a couple of things you can do. Check the plenum, colder thermostat, colder spark plugs or adjust the timing back a little.
