2001 Dodge Ram 360 won't start after cap rotor and pluge/wires
Old May 15, 2009 | 08:26 PM
Mike's Dodge1500's Avatar
Mike's Dodge1500
Default 2001 Dodge Ram 360 won't start after cap rotor and pluge/wires
Hey guys I'm looking to get my 2001 Dodge Ram 1500 going ASAP. Yesterday I removed my stock plugs wires cap/ rotor etc and replaced them . My truck will crank over but doesn't even sound like its trying to fire. I triple checked my firing order and connections and still nothing. I pulled one wire and checked and the spark seems very weak (orange). My fuel pump is pushing fuel and I have good fuel pressure
It ran great before but after 100,000km I changed them to be safe.......lol.....should have left it alone
Appreciate any help I can get
Old May 15, 2009 | 09:19 PM
pdavis53's Avatar
pdavis53
Have you checked to see if all of the plug wires are snapped into place on the rotor. I would also check the wire going to the coil make sure that is tight. I would then take the cap off and make sure that I didn't bend the piece of metal on the top of the rotor and then re-install. Don't get to frustrated it is probably something simple, it usually is. Good luck
Old May 15, 2009 | 10:11 PM
dwilkinson's Avatar
dwilkinson
Mike:
Check and make sure rotor was put on correctly. Make sure the tab on the rotor matches up with slot on shaft.
Old May 15, 2009 | 10:39 PM
dblj16380's Avatar
dblj16380
I agree with the guys above that it is probably something simple. If you are getting a very weak spark then that right there is your problem. I would start tracing it down. If it is weak on all plugs (or at least a couple) then I would check the new distributor cap and rotor. If that seems well then keep going back on the ignition system.
Good Luck.
Old Sep 7, 2009 | 09:52 PM
davideblinn's Avatar
davideblinn
Default 2001 dodge ram wont start
i know this is an old post but i just googled the same problem, 2001 ram wouldnt start
had power from starter, ignition coil, but no power going to the plugs..
if you have power past the coil and wont start it should only be, the distributor or the crank shaft sensor and the way to tell the difference between the two.....
try to start your car and if your RPM's dont move when your trying to start its the sensor, if it is moveing its the distributor.
Old Sep 8, 2009 | 10:54 AM
pavement_hater's Avatar
pavement_hater
I had the same problem once. Seems the threads on my dist. were messed up a little and I thought the cap was tight. Turned out it wiggled just a little and the first time I tried to start it, it snapped off the end of the rotor. After running a tap through the threads to insure the bolts screwed all the way down and installing a new rotor, it was fixed.
