Best stuff to pour in gas tank?
I've used the lucas in the gas before (have a big bottle of the stuff in the garage), but im hesitant on the engine restore. Lately i've been blowing smoke on startup sometimes so I think it is my piston rings. I may break down and actually try the engine restore, but first I think I am going to throw in a heavier oil to see what happens. What weight would you guys recommend? 10w40 or something different?
If it was rings or intake valve seals the smoke will be the all the time... (More so on long downhill grades)
Between MMO Chevron and seafoam witch one will clean the injectors and stuff like that the best? Also after using any of these should i change the oil in a few 100 miles i know with the sea foam i will and its almost time for an oil change.
What is MCCC i tried searching for it and couldn't find anything
Yeah... but I've thought for the past two years that my heads were cracked for some odd reason (just have that feeling) expecially after everyone elses started poping up. I get a wierd stumble on startup sometimes which I can't seem to cure for the past two years no matter what I replace. I've wanted to do a compression test for a good while, but never got around to it. Plenum is still stock with 104k on the clock. I've concentrated on other stuff with the truck, and I guess its time to start working on the motor. But right now inspection and registration are on the chopping block first.
